Well, the two ARX treatments of my 99.5 Jetta VR6 (currently with 182,750 miles) are done, so I figured I would post my findings. Here goes ...
BACKGROUND
The engine in question is your typical high mileage VR6 - still runs great, gets decent fuel economy on the highway (30+ MPG - "spirited" driving in the city is another story though) and burns virtually no oil. Even so, I decided to do these ARX treatments to see if they would get rid of a ticking noise I've had for quite a while and that I suspected was a worn/sticking hydraulic lifter (see this BITOG thread for more info).
OCIs on the engine have been every 10k miles. Dino was used (whatever crap the dealer put in and most likely 5w-30) up to 100k miles and "synthetic" was used from 100k miles on (Castrol Syntec 5w-30, Mobil1 0w-40 and Shell Rotella T 5w-40). OEM Hengst filters have always been used. Other than the ticking noise, the engine has never had a major problem and has only been opened up to change a cracked timing chain guide (very common on the VR6). Compression numbers are uniform and higher than VW's "new" spec. The engine runs flawlessly, has great power, clutch is still original, uses roughly 1/2 qt. of oil over the 10k OCI ... what more could I ask for!?
And now on to the good stuff ...
PRE-ARX DATA
The pre-ARX compression numbers were ("new" spec is 147-191 psi):
Cyl 1 - 226 psi
Cyl 2 - 216 psi
Cyl 3 - 225 psi
Cyl 4 - 220 psi
Cyl 5 - 217 psi
Cyl 6 - 221 psi
Image of filter removed before adding ARX (4655 mile OCI)
1st CLEANING PHASE
Start mileage = 174,875
End mileage = 176,510
Miles for phase = 1635
Oil used = Shell Rotella T 5w-40 (added 14 oz. ARX at 4655 miles into OCI)
Filter used = OEM Hengst
Compression numbers after 1st cleaning phase (with change from previous) ...
Cyl 1 - 225 psi (-1 psi)
Cyl 2 - 217 psi (+1 psi)
Cyl 3 - 224 psi (-1 psi)
Cyl 4 - 227 psi (+7 psi)
Cyl 5 - 218 psi (+1 psi)
Cyl 6 - 221 psi (0 psi)
Photo of filter after 1st cleaning phase
1st RINSE PHASE
Start mileage = 176,510
End mileage = 178,850
Miles for phase = 2340
Oil used = Castrol GTX 5w-30
Compression numbers after 1st rinse phase (with change from previous) ...
Cyl 1 - 227 psi (+2 psi)
Cyl 2 - 217 psi (0 psi)
Cyl 3 - 220 psi (-4 psi)
Cyl 4 - 226 psi (-1 psi)
Cyl 5 - 218 psi (0 psi)
Cyl 6 - 222 psi (+1 psi)
Photo of filter after 1st rinse phase
2nd CLEANING PHASE
Start mileage = 178,850
End mileage = 180,196
Miles for phase = 1346
Oil used = Castrol GTX 5w-30 (plus 14 oz. ARX)
Compression numbers after 2nd cleaning phase (with change from previous) ...
Cyl 1 - 225 psi (-2 psi)
Cyl 3 - 222 psi (+2 psi)
Cyl 4 - 226 psi (0 psi)
Cyl 5 - 219 psi (+1 psi)
Cyl 6 - 217 psi (-5 psi)
Photo of filter after 2nd cleaning phase
2nd RINSE PHASE
Start mileage = 180,196
End mileage = 182,360
Miles for phase = 2164
Compression numbers after 2nd rinse phase (with change from previous) ...
Cyl 1 - 228 psi (+3 psi)
Cyl 3 - 223 psi (+1 psi)
Cyl 4 - 222 psi (-4 psi)
Cyl 5 - 219 psi (0 psi)
Cyl 6 - 228 psi (+11 psi)
Photo of filter after 2nd rinse phase
EFFECTS OF THE ARX TREATMENTS
The effect of the two ARX treatments on compression were ...
Cyl 1 - 226 to 228 psi (+2 psi)
Cyl 2 - 216 to 217 psi (+1 psi)
Cyl 3 - 225 to 223 psi (-2 psi)
Cyl 4 - 220 to 222 psi (+2 psi)
Cyl 5 - 217 to 219 psi (+2 psi)
Cyl 6 - 221 to 228 psi (+7 psi)
I haven't removed the valve cover yet to see what the top of the head looks like (I'm not expecting a big change however), but I did drop the oil pan and found the following.
Oil pan with and without the remaining oil removed (Look at how much oil is left in the pan after a 15 hour drain!)
The engine runs the same as it did prior to the ARX treatments. It still has great power, fuel economy is unchanged, and unfortunately, the ticking noise is still present.
I'm not going to make any comments about whether ARX works or why my results turned out the way they did. Although I'm still a believer in ARX, I'll let you make up your own opinions about my experience.
Gary
BACKGROUND
PRE-ARX DATA
Cyl 1 - 226 psi
Cyl 2 - 216 psi
Cyl 3 - 225 psi
Cyl 4 - 220 psi
Cyl 5 - 217 psi
Cyl 6 - 221 psi
1st CLEANING PHASE
1st RINSE PHASE
2nd CLEANING PHASE
2nd RINSE PHASE
Gary
