I started the cleaning phase at 21,543km with fresh Toyota 10w30 dino oil and a new Toyota Denso 90915-YZZA6 oil filter. 2,686km / 4.5months later, I drained the oil and cut open the filter. Well, first I discovered it was a big mistake to use the older paper type pleated element (2AZ-FE calls for the newer yellow foam type 90915-10004), I was hoping the paper type would be better to show the sludge being captured between the pleats. The first pic shows the disaster that happened, the paper element had collasped internally, you can see the central section is squished inwards all the way around. There are supposed to be vertical slots, 6 of them, for oil to enter the pleated elements, but bcos it has collapsed, there is now very little gap for the oil to enter the pleats. There is a possibility that oil escaped thru the bypass instead. I dont know. The good news is that there didnt seem to be any breakage of the paper element or its seal. As you can see on the last pic, there was no sign of sludge at all. This car has always used synthetic at 5,000km intervals (Castrol RS 10w50, Castrol SLX 0w30 and SPC Synace Max 0w30). Maybe 21,500km is too early for cleaning.
I will post pics of the oil filter after the rinse phase.
[ May 09, 2005, 09:30 AM: Message edited by: Ken4 ]
![[I dont know]](/forums/graemlins/dunno.gif)
