I have read here that adding ATF to oil makes a good cleaner. Another post suggested that it was not a good idea. Does ATF make a good (safe?) engine cleaner? If so how much should be added and how long should you run it through the oil? What type of ATF; Dexron, Type F, doesn't matter?
