Ive got an automatic Suzuki Aerio SX, the dipstick for this has always been a mystery for me(as well as others). Since the day I drove it home its always read off the end of the full mark, no matter the method of checking(hot, cold, at idle)...after driving the car for almost 3 years Im beggining to doubt the level of the factory fill. Granted Ive "replaced" the ATF several times. Its always drained 3 quarts and Ive always refilled 3 quarts, so the level has always stayed consistant. It doesnt overflow out of the breather or anything and the cars shifts nicely.
I dunno if I should believe the dipstick or if I should adjust the level?
Would having too much ATF cause excess heat issues? Would having less cause it to run cooler?
These are the fluid specs:
6.2L or 13.1pt when overhauling.
2.9L or 6.13pt when draining from drain plug hole.
