MolaKule
Staff member
I totally agree. Even Transmission shops don't seem to get it. Some here push M1, even though EM says no.quote:
Originally posted by JeepZJ4.0:
X2!!!!!!!!!quote:
Originally posted by G-Man II:
Just make sure you get a WRITTEN warranty from Amsoil stating that they will replace your transmission when it craps out from using this fluid. FACT: There are NO aftermarket ATFs that meet Chrysler 9602 (ATF+4) specs.quote:
Originally posted by Scott:
Am I reading this correctly? It seems that this AMSOIL product is ATF+4 compatible. IT soudns like this will be OK. Can someone with experience confirm this product will work.
http://www.amsoil.com/products/atf.html
Thanks!
Scott
STICK WITH ATF+4!!!! IT IS A SYNTHETIC!!! DON'T TRY AND SAVE A FEW BUCKS!!!! GET THE FLUID THAT WAS DESIGNED FOR THAT TRANSMISSION!!!! THERE IS NO SUBSTITUTE FOR ATF+4!!!
quote:
Originally posted by TooSlick:
Amsoil and their additive supplier jointly developed this universal fluid five to six years ago. There are tens of thousands of folks using it all through North America with excellent long term results. The fluid has been extensively bench and field tested are NO durability issues with this fluid, period. I feel entirely comfortable recommending it for Chrysler transmissions under warranty ....
Tooslick
I thought ATF+4 was only released in 2000? How can amsoil be tested and rated then?
www.lubedealer.com/Dixie_Synthetics
Certain 1999 model year Chryslers (like my 99 300M) came with 9602 spec ATF (AFT+4). The problem with all these companies claiming their universal fluids meet this spec is that Chrysler specifies not only the performance parameters for ATF+4, but also the exact chemical composition, right down to the base oil blend and additives. This "recipe," as well as the performance specs, are proprietary and have not been released to oil companies for use in making "service fill" aftermarket fluids. There are two companies that make ATF+4 for Chrysler: Equilon (or whatever it's called now by Shell) and PetroCanada.quote:
Originally posted by Mitch:
Tooslick
Is Chrysler ATF+4 really synthetic?quote:
X2!!!!!!!!!quote:
Thanks!
Scott
Do a search. This topic has been discussed numerous time before, and I've posted links to where I got all my info, namely: the online catalog for PetroCanada, the online MSDS database for Equilon, and two or three lube industry trade articles.quote:
G-Man II, where did you get your ATF+4 information?
Two different topics here and two different beasts with third party info.quote:
My question is that if Amsoil's ATF won't work correctly or causes problems in a Chrysler Manual transmission, how can it possibly be used in a Chrysler Automatic transmission?
Just to clarify, ask the question from another persepctive.quote:
How does [the] frictional plate material know which friction modifier to pull from or select, from [among] the many FM's in a universal ATF?
