Originally Posted By: NHHEMI
Redline is GREAT oil so don't get me wrong here but aren't you worried about taking a risk like that on such an expensive vehicle? Running an oil that won't meet your warranty requirements on any vehicle, let alone a more expensive brand with higher repair costs like a Lexus, seems unwise. I wouldn't do it until warranty expired but obviously it is your vehicle so your call.
I appreciate your concern but I've used synthetic before the warranty ended for over 25 years with a number of vehicles.
So far,so good.The chances of a warranty issue due to a oil problem are very,very small.
Even if a problem happens,I may even have a chance to change the oil before the car is brought into the dealer service.
Has nothing to do with Redline being synthetic. I run synthetic in my vehicles as well. The issue is Redline offers no API Cetified oils and that can be a problem for you if you suffer engine failure. Also, won't matter if you change the oil if you suffer a catastrophic/lubrication related issue. The car mfg is most likely going to request your OCI documentation to see that you used the correct weight and rated oil and that you changed it on time.
I actually have worked in a dealership parts & service department( not Lexus but they are all the same )and routinely we asked for proof of proper maaintenance when none existed on the computer for that vehicle. With all car mfg's having financial struggles these days they let less and less slip by and they have tightened up making sure that dealers check stuff like that. Car mfg's takes the use of API Certified oils very serious.
I do agree the chances of there being a problem are very small. That doesn't mean none though. My Sister bought a brand new vehicle that needed a new engine within the 1st 3 months. It happens. Hopefully you have the coin to fix the problem( or hire a lawyer )if one does happen though because I can assure you that Lexus WILL ask for proof you did everything right before doing the repair and if you can only show Redline for OC's they are going to balk at any repairs.
Good luck.
I've used non API Cetified Amsoil for years before Redline.I was never worried with Amsoil because Amsoil will take care of any problem caused by the oil.
I don't think Redline does that so there's more of a risk.I may go with Amsoil SSO or 5w30 ASL in the ES for Amsoil's backing in case of a problem.Got to stay with RL in the RX because it has helped with the piston slap noise.
Both V6 engines have been around for years so I'm not worried.A new engine design would have me more worried.
I also have a buddy who has a shop and does all my work so oil change receipts and type of oil isn't a problem.
A Lexus warranty is 4/50.Too long to wait.
