I’m asking for help from anyone with a Nissan Sentra with the 1.8 Liter Engine with either Automatic Transmission or Manual Transmission. I have a 2019 Nissan Sentra S 6 speed manual transmission with the 1.8 Liter Engine I purchased new in 2020 and it now has approx 7500 miles on it. I have engine noise after my car has reached full operating temperature. I think the noise might be normal but I don't know anyone else that has the same car as I do so I'm not sure. Please help me by checking your car and responding back to me with the results on this forum? To test your car let the engine reach full operating temperature then let it warm up at least an additional 10 minutes. Put the parking brake on and turn off the AC, Fan and Radio and put transmission in neutral (or Park or Neutral if it’s an Automatic Transmission) then take foot off of the clutch if it’s a manual transmission. In neutral bring engine to 2000 to 2400 RPM and hold it steady at a constant RPM and you can hear the noise a definite lite knocking or tapping or chatter and you can vary the RPM up and down within 2000 to 2400 RPM and also hear it. I do not hear the noise when driving the car except occasionally a little between shifting gears at slow speed when road noise is low. I also do not hear the noise until at least 10 minutes after the engine has reached full operating temperature. If your car has the same noise then I will likely conclude that the noise is normal. If not, I might need to take my car to my Nissan Dealership for possible warranty work. It sounds to me like timing chain slack noise but I'm not sure. Please let me know your outcome on this post, after you check your car. Also, can you let me know what Oil and Filter you are using...I changed my oil at 4000 miles with Quaker State Ultimate Durability Full Synthetic 0W20 with an OEM Nissan Oil Filter. Thanks to all for your help!
