Now that gasoline prices are pushing $2.10/gallon in Massachusetts, it got me to thinking about the longer term cost of using an "energy-conserving" oil as opposed to a "wear-metal-conserving" oil.
I just switched from GC to a mostly Pennzoil Platinum 5W-30 (with one quart of M1 0W-40 to thicken it up a bit, use up my stash), and with similar weather and driving patterns, my first tank of gas netted me 25.13 mpg vs 23.75 with the last tank I ran on GC. That's almost a 6% increase in fuel efficiency.
6% of $2.10 is almost 13 cents a gallon, over 15 gallon tank, that's $1.89 saving per tank of gas! Extend that out over 18,000 miles a year, that's a savings of about $87 a year.
So, purely from a gasoline savings point of view, if I can justify spending up to $87 dollars a year on more "energy conserving" oil, I'll do better in terms of gasoline expenditures.
These numbers only favor "energy conserving" oils more and more as gasoline prices go up.
Don't know what will happen to my wear metals in this current OCI, but I have some confidence that it will be more than OK (it's a non-turbo Subaru). And frankly, I have no price difference between GC and PP/M1.
Looking at this issue from 30,000 feet, however, it begs some questions...
- Will you see significantly shortened engine life with a more "energy conserving" oil?
- Will you see significantly higher maintenance costs with a more "energy conserving" oil?
- What is the added benefit of reduced environmental load using more "energy conserving" oil?
I haven't driven long enough to know the answers to these questions, but my gut feeling tells me that it's good to burn less gasoline, all other things being equal.
Now that I've started, I'm really interested to hear what the BITOG elders and not-so-elders have to say about this topic!
