To maximize the effectiveness of an ARX cleaning, instructions should be followed. Mineral oils, simple dino is the best way to go. As ARX penetrates into sludge and hard carbonized deposits it sets the stage whereby the deposits are now there for the taking into the host oil. ARX impregnated deposits are suspended into the host oil and carried to the filter media. The process is very slow and methodical and is simply best accomplished in simple dino oil formulations.
As a kicker the rinse is for only 2000 miles, why shell out the extra scratch on any higher priced oil. Plain Jane Chevron, Castrol, Penzoil, Haviland, and many others work very well. What you should avoid in the rinse phase are the "high mileage", or "start up protection" oils. They do not accept the impregnated deposits as well. And unless you motor specifies full synthetic only, synthetics don't function as well either. If your motor requires synthetics, run the rinse phase longer, 3000-3500 miles.
The folks at ARX agree that the normal cleaning cycle can be extended beyond 1500 miles, but chose not to recommend it because of a fair number of neglected, highly sludge motors out in the market place.
The reason why we don't like any "start up protection" oils is that they they have polar attraction to metal. Its very difficult to rinse parts clean with polar cling.
These oils are perfectly fine to run once your application is complete, cleaning phase and rinse phase. As a matter of fact these oils will function better with clean metal surfaces to work with.
These are my observations using ARX in over 30 cars, in the last 5 years.
