I have variations of a question that I imagine is asked relatively common on here. They are as follows:
1. From my understanding, you need to change oil yearly, even when you don't run the engines, because humidity creeps into the oil through time. Is that correct?
2. Does this still apply even in states like Arizona where humidity is super low. I can't imagine there is nearly the same rate of humidity accumulation in FL as AZ for example. Or am I misunderstanding the process?
I imagine the "do I really need to change it" question would be an easier answer for standard commuter cars. However, the only engines that I run into the "not used enough" problem is with my "toys". I'm not sure if their engines are considered higher risk. Anyways what do you guys think of the following situation, change or not, considering the place they were stored (AZ).
3. Dirt Bikes. I use Rotella T4 15w-40 for them and they have ran maybe 30 miles or so in the last year.
4. Maverick X3 Turbo . I use the Can Am approved oil. When it is ran , it is almost always for atleast 30+ minutes, so it's not super short trips. It is recommended to change the oil every 2k miles, or 100hr run time or 1x a year. It has been a year, 200 miles and 14hr run time.
5. 2007 Malibu 23lsv boat (350 Monsoon). It is recommended to change the oil yearly or every 50 hours run time. It has been 1 year and 18 hours. I use the Rotella T4 in here as well. The one thing that makes this one different than the others is it is stored by the lake (parking lot a few hundred feet from the lake). So even though it is in Phoenix, I'm not sure if the proximity to water and the fact that it gets run on water increases the humidity that makes it into the oil.
What do you guys think?
