If you have a big old snot of something in the carb, the higher vacuum of a running engine might pull it through, vs a cranking engine.
My dodge w250 plow truck loses its prime every summer. First start of the winter takes about 20-30 seconds on the starter, pumping the mechanical fuel pump to get the gas back up into the carb. If I ran the truck off of starter fluid, this would go faster and be easier on my starter. But ether is expensive and my starter was $27 at Pep Boys.
