I'm not a fan of wheels that are setup as lug centric and would much prefer a hub centric design. However, I seem to have a somewhat uncommon setup (5x114.3 bolt, 66.1mm bore, 35mm offset) such that it makes shopping for replacement wheels challenging from the classifieds.
I noticed it is possible to get aluminum hub rings instead of plastic. Therefore, if I use an aluminum ring to go from my 66.1 bore to 67.1 or 73.1, would this effectively turn it to a true hub centric setup such that the hub becomes load bearing?
