It seems to me that using Used Oil Analysis in an attempt to judge distinctions between motor oils has a lot of problems with it which makes much of the speculation and conclusion drawing here on BITOG highly suspect.
1) Any wear particles which are trapped by the oil filter (which is after all an oil filter's job) are not left in the drain oil and are therefor not detected in a simple oil analysis.
2) Any wear particles which are left behind as deposits in the engine likewise do not show up in the oil. Thus lower solvency oils might have an advantage in UOA which is not representative of reduced wear.
3) None of the standard engine oil testing methods uses oil analysis as a wear measurement method. All of them use reference engines or other reference bench set ups, run the system through a sequence of operations, then make physical measurements on key parts to determine how much wear happened. I have never seen any data published anywhere which correlates these methods to analysis of used oil. Without demonstrated correlation, we are just assuming that low metal numbers in used oil mean low wear happened.
I am starting to understand those who have shouted from the mountaintops that UOAs are for watching engine trends, catching worn out oil (TBN, viscosity, etc) and for catching contamination problems like blown intake or head gaskets.
The use of UOAs to pass judgement on fine distinctions between various oils based on metal levels does not really make a lot of sense.
Using VOAs to judge oils is even more silly. There is more we don't know about an oil than we can ever learn from a simple minded VOA.
Other silliness is getting all excited about the Connoco oils (Motorcraft, TropArtic, etc.) because they are "Synthetic Blends". Pennzoil, Chevron and others choose to meet GF-4 requirements by using a high quality Group II+ base stock from the get go and Connoco chooses to use mostly lower quality Group I with a Group III or Group IV kicker. Which way is better? Heck, who here really knows? Maybe it makes no difference.
Just some things to think about.
John
John
