My wife hit the curve twice on the same steel rim on my 2003 Toyota Echo and destroyed its tire. After putting on a new tire I drove it on the highway for 30 miles with average speed 60 mph, and then the tire became flat. I put on the donut spare and limped to a tire shop to put on another new tire. Again the 2nd tire became flat under the same condition after 30 miles on the highway. I hope the 2nd new tire can be salvaged since I stopped the car a bit sooner.
1) I guess the steel rim was probably bent causing air leak, but visually I could not tell if it is bent. Can you think of any explanation other than a bent rim?
2) Can a bent steel rim be repaired at a local garage?
3) Assuming the rim is bent beyond repair for a replacement, should I buy a brand new or remanufactured OEM steel rim? The price difference is about $25. Do you have good experience with a remanufactured OEM rim that you can recommend a seller?
Thanks.
Thanks.
