I believe the primary difference is the SL designation and what it entails around the phosphourous cap of 1k ppm which would also lower the Zinc content. Also the higher end M/C oils use a more expensive VII's when needed that are less prone to shear,not much different than some of the HD oils these days.
Some think the SG designation is inferior as in the base oil. I have here new 10/30 HD oil from Conoco thats SG but it has a mix of group III-Group II base oils.
Do you have a certain brand and series you are thinking of trying out?
[ January 13, 2003, 05:03 AM: Message edited by: dragboat ]
