Originally Posted By: edyvw
Originally Posted By: Proxyon
In Greece.
It becomes really hot in the summer here with ambient temperatures exceeding 38C (100 F). I still do not know if 5w30 or 5w40 would be better.
It was here on this forum time ago when I was advised that the ESP was probably not the best option for my gasoline engine. People were like: "Why would you put recommended oil for DPF diesel engines with C2/C3 specs on a gas engine when you have plenty of other options."
I ignored it, so far no issues with the ESP, however, after this advice has always sounded in the back of my mind. And probably there is a good point on it.
I am originally from Bosnia and I know Greece climate very well.
DO not worry. Greece climate is not as hot as in southeast US or deserts here.
5W30 will perform in your Accord perfectly fine in Greece. Take into consideration that Mobil 1 ESP 5w30 HTHS is 3.58 and HTHS of Motul 5W40 X-Clean is 3.64cp! That is negligible difference.
I was running Castrol 0W30 in Alabama where temperatures reach in summer 115f, and humidity spikes to 98% with no problems. I was running Mobil 1 ESP 5w30 oil in Tiguan in Colorado and visiting Moab, UT in July where temperatures go well above 100f.
If your Accord is Direct injection engine, ESP might be much better solution due to lower-SAPS content. If your engine is NOT DI, then you could go to ACEA A3/B B4. There is pretty good evidence that Low-SAPS oil such as ESP will leave less deposits on valves then High-SAPS oil.
My Accord is INdirect Injection, NOT a Direct Injection. It is a traditional injection (where the nozzles are in the collector (don't know if I know the correct English vocabulary and technical competence to explain it).
Since it is not DI does it mean that in my case I should probably go with A3/B4 or just ignore it is not DI and continue with ESP?
In Greece.
