XHVI
Can I nitpick what you wrote about diesels?...
Many diesel engines without glowplugs either need heat on the waterjacket or prelubed oil to start, or they'll need starter fluid sprayed into the air (not good, but it gets the job done...one time I had to start a 2700hp ALCO in below freezing weather and the engine heat was inadvertently off...I sprayed two cans of ether at the same time, the engine rattled 'n banged, but it started).
Diesel fuel combustion is not accurately described as an explosion--the amount and duration of fuel injected is timed to avoid excess combustion pressure. I've pulled indicator cards on engines that show the pressure rise vs. the piston position, so we are sure that the timing is correct and pressure spikes are avoided. The engine is indeed stout, for the compression pressure, for the combustion pressure, and for long life.
Ken
