That is also a Baldwin B243, which I believe is a much better filter. If you have the room, I would recommend the B2HPG Baldwin, which is a ceramic filter, that filters to 5 microns.O.D. :B243 is 3 (76.2) by 4 27/32 (123.9) 8 PSI by pass valve. The B2HPG is O.D. 3 3/4 (95.3) Length : 5 9/32 (134.1)8 PSI by pass valve Application call for a B33 which is 2 11/16 (68.3) Length : 3 (76.2) 14 PSI by-pass valve.
Length : 4 27/32 (123.0)
