Frank
Member
Member # 34
posted May 01, 2003 10:15 AM
Go to
www.auto-rx.com and there you can read how Auto-Rx cleans seals (both buna & silicone)in
industry we refurbish seal material in 55 gallon
gear boxes without down time or seal replacement
and we do the same thing in car engines. Auto-Rx
does not "Swell" seals. We make them pliable as
they were when first installed and can clean behind them. Auto-Rx uses the petrol chemistry of new "Conventional Oil" to harden seals back up for proper fit against metal. Auto-Rx can not harm seals. However the idea is to stop seal leak and application instructions make procedure clear.You can leave Auto-Rx in indefintely without fear of any type damage. Hope this answer your question.
Auto-Rx will remove ash-carbon from internal oil lubricated rotating engine parts. This board has multiple posts from members on Auto-Rx cleansing benefits.
[ May 01, 2003, 10:17 AM: Message edited by: Frank ]
Posts: 177 | From: Ormond Beach Fl | Registered: May 2002 | IP: Logged |
