I'm thinking calibrating a dipstick, before the transmission is drained and before any leaks will work. I agree with JTK, it is a deterrent and a tool to force customers back to the dealer for service. I am going to investigate the dipstick from the 06 Liberty. Then do as demarpaint said and have my father mark it hot and cold, before any work is done.
I just want to confirm the proper way to check an AT hot for a Jeep. Is it after a run? Or do you drive it, let it idle, then with the brake on shift it through the gears and verify a level? Once I get that figured out I think all the mystery will be taken out of the equation. I'm almost positive they're using the same transmission from 06-09 in the Liberty. So maybe the tube is different but a hot fluid level is a hot fluid level +/- a few ounces shouldn't matter. In effect we'd be making our own dipstick.
Thanks for all the replies,
AD
AD
