Ive already replaced cps and camshaft sensor and nothing. After changing out cam sensor, I cranked engine and it seemed like it wanted to start, but nothing. I can hear fuel pump turn on a little when i turn key on. Is there a way to jump fuel pump?
Yes, I replaced those already.According to the Nissan Altima forum there is a crank position sensor, and a crankshaft sensor. Supposed to be replaced in pairs.
I did use starting fluid. It seemed that it wanted to start for about 1/4 second or so , them nothing, it just cranked over.Try starting fluid and see if the engine attempts to start. Checking fuel pressure and the presense of spark would be next.
I don't see a port to connect to.Test the fuel pressure
The only code that found, was the cps.I used starting fluid right before I cranked it and it gave a hint of wanting to run. Today I checked and it has spark. What is the IPDM self test?Any pending codes? Can you still communicate with OBD? Does it have a smart key and if so is the key light in the dash flashing or solid?
Most Nissans have no port to test fuel pressure. You need to rig something up if that is what you want to test.
I would get a buddy to crank the engine while you squirt starting fluid. If it will fire and run for a bit on starting fluid - you obviously have a fuel problem. You said it sounded like it wanted to start, but if your squirting directly at the TB while someone is cranking it should definitely fire and run for a bit - no confusion.
If it does fire - my guess is fuel pump. Either that or the in tank filter is plugged.
If not - big fun trouble shooting electronics. IPDM maybe - I assume there is the normal Nissan IPDM self test / Active Auto test procedure?
Active Auto Test. Works on most Nissan's of that vintage. It doesn't 100% rule out your IPDM, but it is a start :The only code that found, was the cps.I used starting fluid right before I cranked it and it gave a hint of wanting to run. Today I checked and it has spark. What is the IPDM self test?
Did you use an OEM or Hitachi CPS (prefered), or something else? wouldn't be the first jobber sensor I have seen DOA.
When you sprayed the fluid it shouldn't "want to start" - it should bonafide start - might be short time, but should leave no doubt and run for a second or so. If it doesn't then its most likely an electrical problem.
Do you have a chip key, and if so what is the key light in the dash doing?
