Just wondering if anyone has performed any additive treatments to this car?
Trying to determine overall reliability
Thanks
Quote:
1) If oil maintenance is "weak" the first thing you will notice is a small oil leak out of the lower edge of the lower timing chain cover . Most let this go if it develops - the logic is would you rather consume 1/4 -1Q per 3mo./3750K OR spend 1600/2200$ to repair the leak - its a real bear to get in there properly . Added : Depending on the year and how things express this leak from inadequate oil maintenance can include or start at the front (crankshaft) oil seal . A real "winner" will be leaking forward x2 and will also have leakage at the rear main bearing seal . A "bonus" "winner" will possibly/likely have timing chain tensioner and or guide problems as well . 4) (Front - of course there are no rear) Lower control arms (rear bushing)typically get "loose" in bumpy/hard driving/hi tire pressure/ oversized wheel and tire environments fairly quickly - in any case its a normal wear item between 100-150-175K depending , and does mean replacing the arm as an assembly .(Very easy to check for and to do yourself) . Added : IF powersteering fluid leaks are created or allowed to develop ( fluid , hose , and hose clamps - occ . inner seals on rack ) typically you will wipe out the forward bushing on the same arm and if allowed to go long enough you can start affecting adversely things like inner tie rod and sway bar mounts . As with #1 ,"Normal" or "adequate" maintenance avoids all this . 6)Run the 91 Octane if recommended still - the fuel economy pay back alone will make up at least 2/3s if not all the cost difference never mind all the rest - and there is alot of "all the rest" . Your knocksensors ,sparkplugs ,fuel injecters and AT will thank you on the last two as well . (Your vehicle has a spark retard feature (during shifts) that will with even just mid throttle have no useable margin if you run 87/88 octane and very little if you run 89 ie you will have more "shift shock"). If "converting back" to 91 , it can sometimes take as much as 3/4 tankfuls before you realize all the benefits - it can take a long time for the engine to "relearn" depending . Of course , you can just "wipe" the memory and then drive it a lttle bit vigoriously . Added : On a '98 at least , the factory specified octane range is R+M/2 = 89-93.5 ("normal" altitude) . It is definitely worth staying above 91 and in markets where available running the 93-93.5 . (During part of this vehicles life 91 was the highest available in certain locations (non altitude dependent))
