Any way to fix leaky battery post?
eastern NewMexico
Usually I just replace the leaker with an AGM, problem solved -$200 or more.
Usually when they leak this bad they're near end of their useful life any....
I've got a flooded group 65 (bigger and expensiver) battery in my ford that tests pretty good but it just leaks. I can probably get another year or 2 out of it aside from the leaking.
As far as achieving the means to an end I'm not afraid of electricity, battery acid or melting lead, more afraid of spending $269 not including tax to replace a serviceable but messy battery with a sweet AGM.
The way I figure it I'm probably in it for a new battery, saving this one can be an experiment, even if it fails.
Has anyone ever tired:
Super glue?
RTV?
Cutting off and recasting the post to stop a leak?
It doesn't have to last a real long time, even a few months would be a success.
You could also install those battery felt protectors and change them as needed to retain the battery in service. Maybe double them up.
A Google search claims that epoxy will form a mechanical bond with lead. If attempting the epoxy, I would get the plastic and lead super clean and use coarse sandpaper to get a good rough surface to enhance the bond.
I recommend Gorilla Clear Epoxy for that application. It seems to have just a little bit of flexibility to it when cured.
Super glue?
RTV?
I've repaired two batteries with leaking post seals using epoxy. They both kept the seal until the batteries were replaced, one for 4 years and the other for 2 years. Clean the area well with a toothbrush and baking soda, then rinse well, dry well, rough up the plastic and polish the lead with sandpaper,and apply the epoxy. I went slightly up the post with the epoxy, maybe 1/8 ". I should add that my batteries were not in quite as bad shape as yours. Good luck!
