Any one used this "Sleeper Synthetic" ?
Tennessee
There is a synthetic motor oil on the Citgo web site named Citgo Supergard Synthetic. It comes in both 5W 30 and 10W 30. I have seen no mention of this one from you guys. The 10W 30 reads:
API SL
Flash Pt 485 F
Pour Pt -33 F
HTHS Rate 3.5
Ash .80
TBN 8.5
Vis.@ 40C 63
Vis.@ 100C 10.4
Sounds like it might be like motor honey in my big block Ford next time - with that high Flash Point, HTHS and TBN. Comments Please. Anyone with experience with this one?
I doubt this one slipped by Motorbike. This does look like a very good oil. Problem I have is I never see these other brands/choices out their. I have a hard enough time finding GC in S.Jersey.
Yum, Yum.
I just can't find it as a practical matter.
Is it readily available to you??
quote:
Originally posted by haley10:
Yum, Yum.
Don't know yet. There's nothing like a little "oil exploration". Might have to clear out a space along side my Mobil 1 for this one!
quote:
Originally posted by TallPaul:
Pretty shabby pour point (-33) for a synthetic. Maxlife 10w30 has a -36 pour; Durablend 10w30 is -39.
Those oils have more pour point depressants though because of the lower quality base oils .
Look at the cp's of the Citgo Here
Those two Valvoline oils just got outrun in the cold temp race
Well, that's too close to call. I prefer to see the ccs (cold crank simulator) test and MRV numbers. Pour point can be ambiguous.
Few people would be using a 10W-30 below 0F anyway.
TallPaul, I've just found that pour point data doesn't equate to real world cold starts.
I've seen one dino start better in cold than a "real" syn, although the pour point specs. were 20 degrees different.
All I am saying is don't take these absolute pour point numbers as the gospel.
Yum, Yum.
You are absolutely right. Even beats Valvoline Synpower on the cold crank and pump tests.
