any one know how many quarts??
New Jersey
Hey guys my mother came to visit my family and I noticed she needs an oil change. The manual does not say how many qts. Its a Saturn 2.2L 4 cylinder 2003
live_to_hunt
New Jersey
5 wow thanks I was figuring 4 qts I will grab the 5qt jug. What filter do you run? I think its a paper element filter??
ON, Canada eh?
Yeah 4 for the engine and 1 to go through the engine in consumption... J/K I'm surprised though that it takes 5 quarts for a little 4 banger engine...
JHZR2
Staff member
New Jersey
My 2004 saab takes 6. My 81 MB takes 7.4 or so... Even my 91 BMW takes 5.25. Not uncommon, I guess?
Iowa
Ya, it doesn't pay to guess. My 4 Banger Toyota P/U holds 6.1.
Ohio
I have a 2007 ION and if I dump in 5 quarts the oil level will end up significantly above full on the dipstick. Now I usually end up starting at about 4.5 even though the manual states 5 quart capacity. You might want to do the 4.5 and check it/run it a bit before dumping 5 quarts in straightaway. Not a big fan of the lead weight on a cable ION dipstick by the way.
CT, YL of USSA aka Oceania
Hope this helps - oil capacities for Saturns from a GM document: Saturn Year Description Liters Qt 1996-2008 All Models 1996-2002 S Series 1.9 L L4 3.8 4 2000-05 L Series 2.2 L, 3.0 L 4.7 5 2003-07 Ion 2.2 L, 2.4L 4.7 5 2004-07 Ion 2.0 L Supercharged 6 6.3 2002-03 Vue 2.2 L, 3.0 L 4.7 5 2004-08 Vue 2.2 L, 2.4L 4.7 5 2004-07 Vue 3.5 L 4.3 4.5 2008 Vue 3.5 L 3.8 4 2008 Vue 3.6 L 5.2 5.5 2005-07 Relay 3.5 L, 3.9 L 3.8 4 2007-08 Aura 2.4 L 4.7 5 2007-08 Aura 3.5 L 3.8 4 2007-08 Aura 3.6 L 5.2 5.5 2007-08 Sky 2.0 L, 2.4 L 4.7 5 2007-08 Outlook 3.6 L 5.2 5.5 2008 Astra 1.8 L 4.5 4.8
Nothern USA
 Originally Posted By: JustinH
I have a 2003 saturn ion with a 2.2L ecotech. It takes 5 quarts.
That's interesting. My 02 Cavalier Ecotec the manual says 5.8, but 5 leaves the oil above the full mark.
Florida, USA
I don't know if it applies in this case, but there are two specs usually given, one for initial amount oil added at factory, and one for amount to add for an oil change.
Northern Indiana
+1 I found the same thing with my 2004 Ion.
Buffalo, NY
The 2.2Ls aren't generally consumers of oil. That's the 1.9 SOHC/DOHC in the previous SL1/2 models...
