Any Negatives to Mixing M1?
NJ
Other then not knowing what wt. you will end up with, are there any negative effects of mixing M1? Also curious if all M1 formulas other then D1 are ok to mix and fully compatible with one another?
[ March 26, 2003, 09:25 PM: Message edited by: buster ]
On the oil bottle it reads compatible with synthetic and convential oils, more or less .All sae oils are compatible with each other .That is the way they are made.
Sprintman, did it lower your oil consumption considerably?
