I bought one of these REALLY cheap from an oil/gas field liquidation: https://www.northerntool.com/shop/tools/product_200319387_200319387
Ingersoll Rand Type-30 Stationary Air Compressor - 10 HP, 230 Volts, 120 Gallon Horizontal, 35 CFM @ 175 PSI
The description says:
Can I just use Mobil 1 oil instead? The sight glass is busted from mishandling, and all the EXPENSIVE oil ran out and is gone....
- All Season Select synthetic lubricant increases efficiency; with 2000 hours of service between change outs, it performs four times longer than petroleum-based lubricants
- Purchase an All-Season Select lubricant start-up kit (#15920081), and receive all the parts you need for start-up and the first year of maintenance, along with an extended pump warranty
