Originally Posted By: RodRicerg
Hello!
Which "type" of oil antiwear additive do you prefer: MoS2, Boron Nitride or chemical friction modifier????
Thanks for looking!
Have a nice day
All of the above are really best. Antiwear (AW) additives are activated at different temperatures and pressures inside an engine as it warms up.
For example, polymer esters in oil form a shield at lower temperatures, and mos2 in larger amounts (above about 200 ppm) does this as well. (I think Castrol Magnatec might use polymer esters, and we see Mazda 0w-20 oil taking the heavy-mos2-concentration route to AW at low temperatures, both oils just examples, others too of course.) Note mos2 is mostly a friction reducer in lower concentrations typically seen in most oils.
Titanium is used in some oils, like Kendall and CastrolEdge, and it appears to enhance the old classic zddp at relatively high temperatures.
Hexagonal boron nitride is another that LiquiMoly believes in (Ceratec) and is interesting.
I like an oil that throws a big variety of AW additives in a fully formulated motor oil so all the temperature regimes are covered.
