After seeing some less than Stella Protects here I thought I would cut one from my stash
I wonder who makes these?
Seems I remember they were Wix made? But looks like a Purolator base plate and center tube?I wonder who makes these?
I would say M&H, it has the oval baseplate holes, and no coil spring. Probably cheaper to run them on the Purolator line.I wonder who makes these?
Unfortunately, Mann & Hummel owns Purolator AND Wix now, so consolidation was inevitable.The box says Made by Wix
The by pass valve looks like the same resin board material that circuit boards are made ofView attachment 58887View attachment 58888
Yep, that bypass valve design looks to be the same as some used in Purolator branded filters.Unfortunately, Mann & Hummel owns Purolator AND Wix now, so consolidation was inevitable.
Date code looks to be Oct 25, 2018 ... and it's not in the typical Purolator date code format.Not sure where to look for a date codeView attachment 58892
As noted topic is Purolator construction. A decision for this lowest tier filter likely made by M&H corporate. Same Purolator bypass posted many years ago by Z06 in close up pics. Another more recent pic of Puro bypass posted here. Back in 2019 pics of a Napa Pro Select 21348 was posted also showing Purolator construction. Note similarity to date code format to topic filter, topic 10/25/18. The block lettering used is very similar to, same as Motorcraft filters also made by Purolator. I suppose even though obviously Puro construction, one could say an M&H ProTec.The box says Made by Wix
The by pass valve looks like the same resin board material that circuit boards are made of....
