Chrysler don’t use it - Fiat Chrysler does
I don’t mean general engine oil system pressure, I mean inside the pumping elements inside the Multiair brick. Cavitation might occur when the plungers come back out dropping pressure quickly. Dunno.
And yes, I’m aware you have these in the US, and that the US market Fiat 500 and dodge darts with the same 1.4 Multiair I have in my Australian spec Alfa Romeo Giulietta specify a different oil.
Hence the interest in if anyone over there knows what FCA is really needing for oil in these things…
How would electric solenoids in the “pumping elements“ cause cavitation, foaming, or higher pressure?
Wouldn’t the speculative higher pressure reduce foaming?
Cavitation, by the way, is local boiling (change to vapor state) from low pressure.
Even if the pressure was very low, you’re not getting a vapor state change in your engine oil. You’re just not. If there’s air in your oil supply, which would be the foaming to which you refer, then you have a pump or gallery problem, a mechanical problem, that no oil will ever be able to mitigate.
To answer your question: your FCA needs clean oil of recommended specification.
It does not need dwarf-forged unicorn tears to fight off the imagined giants of cavitation, foaming, or extreme pressure. Those are all mythological elements.
The oil in this engine does more than in some engines, about the same as in others. Oil used as hydraulic fluid has been with us for decades. The increase in oil-actuated components means that there are more ways to contaminate the oil, and more ways that contaminated oil can damage components.
So, I would keep clean oil, of proper specification, in your engine.
And enjoy mythology as a pastime - not as an approach to automobile maintenance.
