Folks,
Yes, I've got a new Honda Accord with the four-cylinder engine, and the "don't you DARE change that oil before your first scheduled change!" instructions in the owner's manual.
Which (get this!) is 10,000 miles or 1 year for "normal" usage (with the filter change at 20,000 miles or 1 year!!). Or, make it 5,000 miles / six months for the oil and 10,000 miles / one year for the filter, for "severe" usage.
Of course, I consider this INSANITY!! If I had my way, I'd switch over to Mobil 1 at 1,000 miles (or less), and never look back!
Anyway, I know this has come up many times before, but let me give you my usual practices, and I'd very much appreciate your advice! I am =not= mechanically inclined, and wouldn't know "moly" if it crawled up and bit me on the leg. However, many years ago I adopted my usual oil change regimen: Change it with Mobil 1 every three months, whether it needs it or not. That's usually around 3,000 miles for me, so it's really the classic three months / 3,000 miles routine.
I know that's probably considered "excessive" to some, but I consider my usage to be =quite= severe. My "commute" to work is about three miles, and about ten minutes. It's so short, I drive home for lunch every day. So, that's four short trips, at least, per day, five days a week. I often get out on the open road on the weekends, but often don't go over 35 miles per hour for a whole week, either. So, I think that qualifies as "severe."
So, my mantra is "get the crud out of the engine," and let's also use Mobil 1 so I don't get so much crud, to begin with. Sure, I probably could get away with six-month changes, but what's the cost to do it four times a year? I go to a shop that's been changing my oil for over 20 years, I give them my Mobil 1 and my own filters, and their charge plus the oil and everything winds up to be about fifty bucks per shot. So what if I blow an extra hundred bucks per year -- it's the cheapest insurance you can buy!!
Gosh, I guess I should also mention that I always plan to keep my cars a =long= time -- "ten years after I'm done paying them off!" Doesn't always work out that way, but that's what I always hope to do!
So, gosh, I'm already past 1,000 miles -- coming up on 1,500. I'd love to change the oil RIGHT NOW, but then again, I don't want to compromise the break-in concept Honda is going for. From my reading here, it sounds like a high-moly oil is the way to go, and it sounds like Mobil 1 is high-moly. So, why not? Should I go for the Mobil 1 right now? Or, should I go for some dino oil this time, then go for Mobil 1 next time, three months later?
So, I'd love to hear your thoughts about where to go from here. And, if you've got a preference for a filter, I'd love to hear that, too. It sounds like the OEM filter (and I've always used OEM filters in the past, other makes than Honda) is made by Fram, and it sounds like Fram doesn't get a whole lot of respect here, so by all means, throw your preferences about that my way, too!
Thanks in advance for your advice, which sure looks like it's far better advice than what I get in most "Honda forums" -- such as "You think you know better than the Honda engineers??" And I'd say, "You mean the ones that say change your oil for the first time at 10,000 miles??" "You betcha!!" :-)
Thanks again!
thoots
