Took the girlfriend's '07 Murano in today because it's turning over slowly and getting worse by the day. I also mentioned the pinging and coolant leak, same as I did last time and I expected the same results but I figured I would waste my breath anyway. They also said they would do a recall on the air intake hose between the filter and TB. Almost forgot, I told them that the powersteering pump was noisy at startup, like it had air in it after sitting for a few minutes.
So I got the call that the car has no codes and the pinging is a fuel issue. Pretty standard response now. Same with the coolant, they pressurized the system and it had no leaks. Standard answer. Popped the hood when we got it back and I could see the entire air filter gasket and part of the paper showing from the air box. I hate to think what it would've done to the engine if I had not checked it and we did one of our off-road mountain trips.
So after reinstalling the air filter correctly I decided to look for the slow coolant leak. I figured since their test showed no pressure loss, the only logical thing to look at would be from the cap to the overflow tank. Sure enough, there was a buildup of thick and crusty coolant where the overflow hose clamps to the radiator. It was obvious it had a slow leak for quite some time. A small ziptie cured the problem. It amazes me that they would do a pressure check without a visual. This was obvious, took me 10 seconds to find it.
Next, I was told that the powersteering pump was working. That's great, I thought my little girlfriend was steering the 3,800lb Murano without any assist this whole time....
The battery cost $68. She approved it before I could say anything. There's no way I would've let them get away with that. Of course they made it sound to her that they were doing her a favor by covering part of this cheap battery. I would rather have spent a few extra bucks for good battery if we were paying anyway.
So this visit was on par with the last, a bunch of incompetent idiots. Last time I made them scan it to prove to them that it was pinging and pointed out the knock retard on the scanner so it would be noted in the paper work. This time I didn't even bother. I'm getting used to having to finish their work too.
I plan on calling them tomorrow to complain but with my temper I knew better than to say anything today.
So to not sound completely negative, they washed it and got it almost clean without too many scratches.
