The thread is about 300 Letter cars, a great performing highway vehicle. So, my comments about the Chev and the Fury are also about highway manners.
Tire size is over 2/3 inch shorter on the Chevy (you're using an "interchange" number which is not quite relevant).
http://www.cokertire.com
http://www.tireguides.com/tip6.html
Tire interchange was to avoid tire cross-section interference. Usually, the "modern" tire size recommended is too short compared to the old.
You ever actually sat behind a big block running 3,300 rpm
all day? I have, and don't recommend it. 2,600 rpm is about the right number in all cases (and we used to run 65-68 on those open and nearly truck-less Interstates of the 1960's in the West for reasons of fuel economy [15% improvment on some cars vs 72-75 mph]/engine life/comfort).
Passing times and distances are equal for the Chev and the Fury in both tests. (We should really try to rile the Ferd guys cause that 429 -- the motor design that would have propelled Blue Oval to the top of the heap had the muscle car era lasted -- is a stone, here, even with 2.80 gears. It's an embarrassment).
Sort of like the movie, "Bullit" wherein Bill Hickman, the Charger driver has to constantly keep from overtaking McQueen [not competent behind the wheel], thus the out-of-sequence chase where the Charger has wheel covers in one scene, but not in the [ostensibly] previous scene. 390-Ford, can you say s-l-o-w? Luckily, they pulled MCQueen from behind the wheel.
Here's one recounting:
http://www.hottr6.com/triumph/BULLITT.html
Chrysler always did more with less money. And a 383 would last twice as long as a BB Chev.
We're both car guys, so give the 383 its due: the big block that revved like a small block. I admire plenty of Chevs for lots of reasons.
