I have to start by saying I like both products, so I'm not partial to either, both have advantages and disadvantages.quote:
As opposed to the filters like Amsoil where the oil is filtered around the entire ouside of the media you have a lot of surface area, which makes the capacity mucher higher. But the downside is that you don't have 4 inches of meada for the oil to travel through to be cleaned you only have about 1 1/2 inches to 2 inches.
MSparks: As I understand the Amsoil is a pleated filter, which would give it a high amount of surface area and capacity as you state. Of course, this all depends on how much media they decide to put into the can. However, the oil flow only sees the thickness of the media, and not the length of it, so it probably only travels through about .030-060" of media and not 2".
If you or any other have an AMSoil filter you feel like cutting apart I'll test the media and tell you what pore range it actually is. Just send me a PM.
It's seems Amsoil could have another niche product for the true gear heads on this board and many others out there. As a rep you might want to put in a product request for a finer rated spin-on filter with actual beta ratios backing up it's touted performance. That would definitely raise the bar for the competition and suppress a lot of speculation. It would also allow the customer to know what they are buying. May I suggest a β2 = 1000 which would be a 2µm with 99.9% efficiency. This essentially would end up being a hydraulic filter in your can.
Does the current AMSoil filter have a rated Beta ratio that you can share with us?
