95% of the miles are towing my 8000lb 5th wheel, and/or our 4-horse trailer. I put 8400k miles on the oil in 11 months, and i also replaced the oem filter twice during this OCI.
I don't know how to post the actual report, but i'll list the metals individually.
OAI in SLC, Utah did the report.
Data indicates no abnormal findings. Resample at normal interval; Oil is suitable for continued use.
*********Wear metals ppm*
IRON--12
CHROMIUM--0
NICKEL--0
ALUMINUM--3
COPPER--4
LEAD--0
TIN--0
CADMIUM--0
SILVER--0
TITANIUM--0
VANADIUM--0
*********Contaminant metals--ppm**
SILICON--14------This is high due to use of oiled TRD filter.
SODIUM--10
POTASSIUM--0
*********Multi source metals ppm**
MOLYBDENUM--10
ANTIMONY--0
MANGANESE--0
LITHIUM--0
BORON--22---SSO have boron in it, or is this due to 1/2 quart ASL topoff at filter change?
********Additive metals ppm*
MAGNESIUM--13
CALCIUM--3558
BARIUM--0
PHOSPHOROUS--583
ZINC--676
DATE sampled--7/18/10
Date received--7/27/10
Unit time--11 months
Lube time--8400 miles
Lube change--yes
Filter change--yes
FUEL--less than .1%
SOOT--less than .1%
WATER--less than .1%
VIS @ 100.C--10.4--Spot on virgin which is 10.3
TAN---not listed
TBN--4.96
I-R OXIDA--41---A little high?
I-R NITRA--22
My total miles on the truck are 36k.
I am not so dissapointed in the UOA after using this high end oil. However, the truck is a little noisy on the lower visc. oils for some reason. I just replaced this oil and filter using HDD 5w30 and TRD filter, even though toyota recomends a 0w20 or 5w/20 for this motor. We'll see how this run of the 30w goes next year. So far, it's much quieter.
Please comment.........
Thanks
IRON--12
CHROMIUM--0
NICKEL--0
ALUMINUM--3
COPPER--4
LEAD--0
TIN--0
CADMIUM--0
SILVER--0
TITANIUM--0
VANADIUM--0
SODIUM--10
POTASSIUM--0
MOLYBDENUM--10
ANTIMONY--0
MANGANESE--0
LITHIUM--0
MAGNESIUM--13
CALCIUM--3558
BARIUM--0
PHOSPHOROUS--583
ZINC--676
Lube change--yes
Filter change--yes
FUEL--less than .1%
SOOT--less than .1%
TAN---not listed
TBN--4.96
I-R NITRA--22
Thanks
