Originally Posted By: kschachn
Originally Posted By: stosh1
AAACK, first of all, sorry for the bad grammar & typos above. Uuumm, I guess mostly from the std. "pressure" type wear testing that I've seen. One ex. would be from the previous page:
https://540ratblog.wordpress.com/ His results seem to mirror most testing that I've either seen on the interwebz or heard about. Do you have any links or evidence to support or reject it?
Oh boy. There are numerous threads on this board about that website, all of which explain in excruciating detail how it is worthless - both in methodology and data collection.
Please don't tell me you joined and posted just to resurrect this "test"?
Not doing this out of the sake of defending anyone, but there was a time when we were all new here and in that vain I could understand how this test could be seen in a positive light without knowing the extensive discussions that took place here.
That said there's no real proof for or against using a particular grade of oil over another. Some may be more right than others in certain applications, though most choices against using the manufacturer suggested grade tend to be engine sound or "thicker protects better." European oils have different required specs and the main reason is for extended oil change intervals. Whether or not Xw40 is a must, it is the easiest to source in the US that meets specifications, but I think most call for 0w-30 or 5w-30. Finding a 5w-30 euro grade requires a bit of digging since your average 5w-30 doesn't meet those specs here with it being a common grade used in other cars with energy conserving being a priority. Due to HTHS specs I don't think there is an "Energy Conserving" labeled European oil out there.
Yes I'm guilty of not using the recommended grade. I'm using 5w-30 in a 5w-20 car and 10w-30 in a 5w-30 car. Jaguar never authorized the use of 5w-20 in the 4.2 V-8 and the previous years of the Lincoln called for 5w-30 in the exactly the same motor. Call it laziness I guess, but I prefer to use the same grade in both cars to make stocking oil easier. I went 10w-30 this time as cold start just isn't a concern here where it never gets below about 25 Fahrenheit.
