I'm getting ready to change gear lub on my 2001 GT Mustang Auto. using Amsoil 75W-140 Seare Gear. Due I need to add a limited slip additive.
Thanks
Dave
Only if both conditions are present:
1--your differential has a clutch-type limited slip unit
--AND--
2--the new gear oil does not have the LSD additive already mixed in at the factory.
--AND--
...or
3--your clutch pack type limited slip still "chatters"/"clunks"/"creaks" coasting around slow, tight turns (as in a parking lot), even if your gear oil claims to already have the additive in it.
AMSOIL Severe Gear is compatible with most limited-slip differentials. If limited-slip differential chatter occurs, add AMSOIL Slip-Lock™ friction modifier additive.
I bought a 4oz tube of the Slip-Lock just in case...But I didn't need it... With the (EP) Gear Lube 75W-140 (SVO)
in my Ford 10.50 rear end...
I think it all depends on the condition of your limited slip clutches...
Sometimes even the material from which those clutches are made.
