Molecule,
It's funny, but I had no problems understanding this data - you must be getting old
Seriously though, just treat the data from 20k-120k as the first run and from 140k to 220k as the second run. There is a fairly large TBN drop in each case after the first 20k miles (from neutralizing pre-existing contaminents), then the TBN depletion slows down. You also have to consider the filter change intevals and the amount of fresh oil that was added after these ....
You can compare either set of data to the baseline, since it was generated under the same operating conditions. The ppm/mile wear and soot data is calculated based on the actual number of miles on the sample run to that point.
