Amsoil Series 2k TRO 20w50 replacement?
Yes the Dominator 15w-50 replaced TRO...lots of variability in the four ball test - those results are basically comparable.
Its not unusual with the lower viscosity to have a lower 4 ball. There will be some TRO around in the warehouses for a little while.
I never really paid much attention to the four ball, but Amsoil has typically regarded it as very important. Also, the HTHS test is under a different protocol d5481. Is there any significance of this change? The HTHS score is slightly lower and I didn't know if this a variance of the test.
Honestly, Amsoil doesn't think all that much of the 4-ball test. They know it's a simple bench test. Regarding the shear stability, the entire Dominator line is extremely shear stable which is why they are giving you the Shear Stability (Kurt Orbahn (ASTM D-6278),% viscosity change 90 cycles) figure.
