Just getting around to posting this. About a month ago I used some Amsoil Power foam intake and engine cleaner on my 97 F150.
The Power Foam comes in a spray can with one of the red straw tips you can use for directing the spray. After reading about the Sea Foam I wanted to do it through the Vacuum line on the Power brake. I warmed up the engine and unhood the vacuum line then I sprayed the entire can of power foam into the line.
The vacuum line suck the stuff right up. I turned off the engine and let it sit about 30 minutes. Then drove off with a huge cloud of white smoke following me :rocker:
In the last month or so I've noticed less pinging. I was getting a ping under acceleration with regular gas. And with the price of gas going up I'm not about to resign myself to use mid or high test.
I talked to the Guy at the NAPA auto parts and he said I should have done this throught the EGR line becuase it goes in the the intake at the throttle body(so that would get cleaned) the Power Brake line goes in futher down toward the Plenum.
So I bought a couple more cans to give that a try. I had pulled the intake tube off and saw that there was a lot of carbon inside the intake. Especially behind the butterfly valve. Hopefully after doing the EGR line we will see even better perfermance.
Here are some pics of the process:
http://f1.pg.photos.yahoo.com/ph/saxnflute/detail?.dir=/Amsoil&.dnm=26d5.jpg
http://f1.pg.photos.yahoo.com/ph/saxnflute/detail?.dir=/Amsoil&.dnm=8bf1.jpg
http://f1.pg.photos.yahoo.com/ph/saxnflute/detail?.dir=/Amsoil&.dnm=5383.jpg
http://f1.pg.photos.yahoo.com/ph/saxnflute/detail?.dir=/Amsoil&.dnm=c44b.jpg
quote:
- Removes gum, varnish and carbon deposits
- Suppresses engine ping
- Cuts through rust and grease
- Improves fuel economy
- Frees stuck choke mechanisms
Cleans entire combustion intake system for improved engine performance. Removes gum, varnish and carbon deposits for better fuel economy and improved overall engine performance. Cleans intake valves, intake manifolds and throttle plates to keep the combustion intake system running at peak efficiency. Effective in both two-cycle and four-cycle engines.
**safe for catalytic converters and emission control devices
