i used amsoil power foam in all my cars, and seafoam.
amsoil power foam usually made the most smoke out of it all.
yet on my 1986 300zx, after its first opening of the intake system had alot of gunk....so i sprayed it off with some amsoil and sprayed in half the can at part throttle...
usually on my other cars i would be polluting the block with a cloud of white smoke but not this time.
there was a slight smell in the exaust but no smoke...i revved it up alot and as high as i can go but no smoke...
so im wondering, did i clean anything out or did the product just evaporate before it got into the valves etc?
i also tried spraying through the brake booster vacumn line, pcv line and everything...took it on the freeway as well and took it WOT every gear...no smoke.
my engine is a v6 3.0l 1986 300zx NA.
