Amsoil OE 0W-20 vs PP 0W-20.....
Everson WA - Pacific NW USA
Originally Posted By: randomhero439
...... but PP beats out OE and XL anyday.
How are you so certain of these things? Please post the data. Not specifications, not thoughts, not certifications, not feelings. Real data.
1/4 Mile Track
People "assume" alot on these forums with no data.I await for proof of this "claim" as well randomhero439
NJ
Where is Amsoil's data? Last time I checked, Shell/Pennzoil used ASTM Seq IVA and IIIG data. What did Amsoil use? 4-ball wear test, then made a video about the one arm bandit. Nice. wink
NJ
No way of really proving that. XL is a very good oil. So is OE. So is PP. They are more alike than different. Look, Amsoil doesn't make a BAD oil. Quality is not the issue with Amsoil. None of these are bad oils.
Ohio
All i have to work with is Spec Sheets. And from my view, PP looks better on paper. Man if everyone was asked to provide real data when making a claim, we would just run ourselves in circles. Most of us look at Spec Sheets, which i guess doesnt count as "real" published data. Your the Amsoil rep, how about you post some real data? Note in my original post, i was refering to base-stock quality, nothing to do with additive packages. ............................(Amsoil OE) (Amsoil SS) (Pennzoil Platinum) Viscosity index:_____166________170_________164 Pour Point__________-48C_______-53C________-54C Flash Point_________224C________232C_______224C CCS Viscosity:____5402cP______4979cP_____5720cP Volatility_________12.6%________9.3%_______8.9% HTHS_______________2.7cP_______2.8cP______2.6cP Looks as though OE and SS have the advantage in CCS and HTHS. However the volatility is clearly superior with PP. To me, i would say OE
New Jersey
Figured I would add qsud to it just for a comparison I got these figures from here hopefully it's the newest one let me know if Its not http://www.epc.shell.com/Docs/GPCDOC_X_cbe_24855_key_140003587110_201007020123.pdf
All i have to work with is Spec Sheets. And from my view, PP looks better on paper. Man if everyone was asked to provide real data when making a claim, we would just run ourselves in circles. Most of us look at Spec Sheets, which i guess doesnt count as "real" published data. Your the Amsoil rep, how about you post some real data? Note in my original post, i was refering to base-stock quality, nothing to do with additive packages. ............................(Amsoil OE) (Amsoil SS) (Pennzoil Platinum). Qsud Viscosity index:_____166________170_________164. 175 Pour Point__________-48C_______-53C________-54C. -48 Flash Point_________224C________232C_______224C. 224c CCS Viscosity:____5402cP______4979cP_____5720cP. 4840 Volatility_________12.6%________9.3%_______8.9% 14% HTHS_______________2.7cP_______2.8cP______2.6cP. 2.6 Looks as though OE and SS have the advantage in CCS and HTHS. However the volatility is clearly superior with PP. To me, i would say OE
PP without a doubt.
So it's just your opinion that PP is better. It's OK to have an opinion, but where is Mr. Newton when you need him? LOL Truth is, no one here can say with anything to back them, one of these oils will actually perform better than the other.
Regina, Saskatchewan, Canada
We all know I like my SOPUS products, but honestly, I don't see anything wrong with either of the Amsoil offerings. I do know that both Amsoil offerings are better than PU, because I can actually go out and buy the former, but not the latter. wink
badtlc
KC
I was hoping to get more feedback from actual experiences, but thanks everyone for the help! I am quite familiar with PP in the 5w20 variety, but not so much in the 0W-20 variety. I have never used Amsoil before. I'm leaning towards Amsoil because I have a small local business that sells it for a good price. It seems as far as protection and longevity, these two oils are on par with each other as PP doesn't have a very strong TBN and what UOAs I have seen with Amsoil OE 0W-20, the TBN retention for this oil is very strong. The higher noack concerns me a smidge, but if I can keep fuel dilution down, it may not matter. I also like the thinner nature of Amsoil OE and it seems to have better cold flow properties despite the difference in pour point. Not sure how that works, but whatever.
Pour point just doesn't happen to be a good indicator of cold weather performance, within reason of course. Obviously, if a pour point is -20 C, it's not going to do well in a cold cranking test and probably wouldn't be a multigrade motor oil. wink Pour point, along with NOACK, can give one at least an indication of base stocks, but even that's getting blurred lately with some of the Group III+ base stocks out there these days.
Ohio
Glad you picked an oil. According to Pablo, you based your choice off of "not real" data. How does that make you feel knowing that Amsoil's and Pennzoil's data isnt real? smile All-in-all im kidding. This is just silly.
Ohio
Originally Posted By: asharris7
I like PP, But there is no way someone can sit anywhere and type "SS and PP/PU are the same base stock."
When comparing spec sheets, PU and Amsoil SS have very similar characteristic. One could assume they use similar basestocks.
Ontario,Canada
Have you taken a look at the Mazda 0W20 with high moly synthetic oil? It is certified by Mazda for use in sky active engines and is GF5 SN. I think it's about $6.80 a quart. Its a little more expensive but well worth it.
badtlc
KC
I have, but I'm a baller on a budget. Plus, from what I can gather that oil likely has a high noack.
Saskatoon canada
Originally Posted By: 147_Grain
For me, Amsoil is all or nothing (pure "100% Synthetic"). Otherwise, I'd just run the PP or PU if you can find it.
The oe line isn't 100% pure syn. Sorry. I do like amsoil though but cost kills it for me. When I can buy jugs for 24 bucks but that same 24 bucks doesn't get me 2 quarts of amsoil I gotta consider value per dollar spent.
badtlc
KC
The OE line should be around $4.50-$5/quart. It is very reasonable.
