- Messages
- 1,383
- Location
- Agrestic, CA
910 Miles with AutoRx in it. Oil was drained. Used an Amsoil EAO filter. Replaced with Castrol 20W50 for Autorx rinse phase. Insolubles look like the AutoRx is working. Did a compression test before AutoRX and the readings were 125-Front 124-Rear (I think Harley spec is >85 with less then 10% deviation between cylinders). I don't expect the AutoRx to increase the compression, but I will post the results of the compression test after the rinse phase.
code:1996 FLHRI (Harley Davidson Road King) Evolution 80ci Gasoline Vehicle miles: 36,996 Miles on oil : 910 Life of oil : 3 months Lab: Blackstone/Dyson Sent to Terry Dyson for analysis. Actual Universal Average Aluminum 1 5 Chromium 1 2 Iron 7 17 Copper 8 8 Lead 1 2 Tin 0 0 Moly 36 40 Nickel 0 1 Manganese 0 1 Silver 0 0 Titanium 0 0 Potassium 9 1 Boron 36 126 Silicon 4 16 Sodium 8 5 Calcium 2772 2190 Magnesium 94 531 Phosph 1100 961 Zinc 1262 1089 Barium 0 2 Sub Viscosity @ 210 = 88.0 Should be 82-95 Flashpoint = 410 Should be >385 Fuel % = <0.5 Should be <2.0 Antifreeze % = 0 Should be 0 Water = <0.0 Should be <0.1 Insolubles = 0.5 Should be <0.6
