Amsoil HD syn oil -- 400K miles w/o oil change
Almost 40k on a fill of Esso XD-3 0W-30 full synth here, GM 3.1L V6 engine. Its not rocket science. You people need an exorcism or something to rid you of the junk that the quickie lube industry has indoctrinated into your heads.
"thou shall not do 3k mile oil changes"
Originally Posted By: TiredTrucker
I followed the recommendation of a couple of drivers and a Cummins tech (which will remain nameless to protect him). It involved letting the engine sit overnight to cool completely. Then, turn key on without starting. Let sit like this for at least 10-15 seconds to ensure EGR valve in closed position. Then unplug the lower EGR plug wire. That's it. No need to repeat process at each start. Only if EGR plugged reconnected.
It did throw a fault code, but no CEL or "limp" or derate mode in the ECM. From others I have discussed this with, certain truck makes will react differently, i.e. throw a CEL or multiple faults. I am concluding that this is relative to the engine model year and how the engine communicates with the truck's vehicle information center. I have a '06 International 9400i with the ISX. Hardly any engine information is passed to the limited display info. From experience, I have seen Volvo trucks display everything up to almost including the last time the driver wiped his rear. Therefore, depending on the engine/vehicle/year combination, the results may be different.
That being said, there are a number of us that have tried this procedure with good results. It would appear that this not a viable option for those with the DPF systems. It seems limited to those with pre-07 EGR equipped ISX engines. The pre-07 engines seem to not have as many sensors giving detailed EGR data to the ECM like positioning and flow rates.
I just tried this with my 05 Mercedes 906. It has 4 wires going into the plug. According to the wiring diagram I have, one goes to the ECU, next one a ground, next one goes to coolant temp sensor and the 4th does nothing (?hard to believe since there's actually a wire). Anyways, I started it and it immediately flashed "decreased output" on the dash. So much for that; I either have to pull a wire out (which one?) or buy another EGR valve and use it as a dummy.
Charlie
Originally Posted By: VW_TDI_PD
I knew, this one guy who deleted the EGR system from his diesel volkswagen and wear rates dropped considerably according to UOA.
Are you talking about me?
I live with the CEL
