Amsoil DEO 5w40, 8K, 04 Dodge 2500HD
Texas
Owner previously maintained 5k mile OCI using Valvoline Premium Blue. Will suggest he run the 10K on this fill as indicated by Blackstone, and then push him to switch over to AME. Make/Model: Cummins ISB 5.9L Vehicle: 2004 Dodge 2500HD
Code:
OIL             DEO 5w40
MILES IN USE    8K
MILES ON UNIT   178,400
SAMPLE TAKEN    12/3/13
MAKE UP OIL	0
ALUMINUM	3
CHROMIUM	2
IRON		44
COPPER		4
LEAD		1
TIN		1
MOLYBDENUM	41
NICKEL		0
MANGANESE	1
SILVER		3
TITANIUM	4
POTASSIUM	3
BORON		29
SILICON		4
SODIUM		6
CALCIUM		900
MAGNESIUM	1232
PHOSPHORUS	1091
ZINC		1222
BARIUM		0
SUS @ 210F	81.2
Visc @ 100C	15.83
Flashpoint	450
Fuel %		0.5
Antifreeze %	0.0
Water %		0.0
Insolubles %	0.4
Blackstone comments: A mildly high viscosity was the only unusual find in this sample. It's still close to the 15W/40 range, and we're guessing the only reason it's up is that you used a little Lucas or something like that. Heat on the oil can cause the viscosity to thicken up, though we aren't seeing any of the other typical signs of heat (damage to the additives or lots of insolubles). And wear looks good. You're running your oil longer than average, and that's why wear is higher than average. The averages are based on ~6,700 miles on the oil. We'd change this fill at 10K.
dnewton3
Staff member
Indianapolis, IN
That Fe seems high for the 8k miles. It's not at a point of condemnation, but it's high. One UOA is not worthy of any decisions yet. Run a couple more and see if the Fe is typical or an anomaly. Do you have any UOA history under the VPB? Would be interesting to see how it ran with the other lube.
TXHunter
Texas
Donald, I'm not too worried about the TBN at 10K with this oil. Much more and I would agree with you. dnewton, this was his first and only UOA on the truck. I agree, wish I had a little more background on the Fe. Hopefully I can get him to run a few more and see improvements in the metals and get the viscosity back down.
