My tailpipe is very sooty, and my oil consumption is less than yours. If you dont get a black finger swiping that pipe, there's a puddle in the driveway. Even if its the PCV was causing it which I doubt, anything going out the PCV goes to top of the plastic intake, then to the combustion chamber. and if the replacement PCV was an aftermarket, it likely has a large inlet hole, not the OE small hole. So it will rattle loudly, like a marble.
Sure, you can run forever burning oil like that but expect collateral damage (which I worked around. anti-fouler). Here's why.
The ECU on your car is programmed for a ridiculously high catalyst efficiency of 95%. Means if your exhaust manifold cat gets only slightly fouled with oil, you will get the dreaded P0420 catalyst efficiency CEL. You will pass inspection emissions with flying colors, but fail for an illuminated CEL. Replacement cats arent cheap, its the welded cat/exhaust manifold. Do what you can to stop the consumption before your stuck replacing the cat or adding an anti fouler to the rear o2
