Amsoil ASM 0w-20; 9,538 miles, '07 Accord 91,795
Ohio
Here is my sample of Amsoil SS 0w-20, one year in service. 80% Hwy/20% city. MM light calls for oil change around 6000 miles (it assumes conventional 5w-20). This was with a Fram Ultra filter. This oil does a nice job with my one year interval but I have changed out to M1 EP 0w-20 with M1 filter simply due to it being 1/2 the cost. I do not plan on trying to go longer than a 1 year OCI. This time next year we will see how M1 EP compares.
Code:
miles on oil        9,538          7,780	5,842        6,358         Universal
miles on unit       91,795         82,257	74,477       68,635        Averages
sample date         08/30/2015     08/26/14     10/26/13     03/10/13
make up oil added   1/2            1/3	        0            0
OIL Type            ASM 0w-20      ASM 0w-20    MC 5w-20     HG 5w-20
Aluminum            3               3	        2            2             4
chromium            0               0	        0            0             0
iron                6               6	        4            5             9
copper              1               1	        2            2             2
lead                0               0	        1            0             1
tin                 0               0	        0            0             1
molybdenum          135             116	        23           43            75
nickel              0               0	        0            0             0
manganese           1               1	        1            0             1
silver              0               0	        0            0             0
titanium            0               0	        0            0             1
potassium           1               8	        0            4             3
boron               64              74	        49           3             47
silicon             18              19	        15           9             13
sodium              15              8	        0            3             46
calcium             3387            3434	2283         2192          2127
magnesium           11              16	        12           14            165
phosphorus          592             676	        760          688           689
zinc                729             770	        794          799           812
barium              0               0	        0            0             0
SUS viscosity @210F 54.8            53.9	48.2         49.5
cSt viscosity @100C 8.70            8.45	6.72         7.12
Flashpoint          350             430	        380          375
Fuel %              1.8             <0.5	<0.5         <0.5
Antifreeze %        0.0             0.0	        0.0          0.0
Water %             0.0             0.0	        0.0          0.0
Insolubles %        0.2             0.2	        0.3          0.3
TBN                 3.3             4.2
TAN
Try a valve clearance adjustment - you're getting near the milestone at which it is due.
Originally Posted By: R80RS
What's going on with fuel?
Normally this car does not do a lot of short tripping but there were a lot for the last few weeks leading up to the sample date. In some cases it was turned on just to move its position in the driveway. I assume this is the reason for the increase in fuel.
Maybe just need to take it for a long drive before sampling? If it had a lot of idling before sampling that would increase the fuel numbers. The wear numbers are excellent. TBN is still decent. Viscosity is good. I would not hesitate to run this oil again in your Accord. You could probably run it another 2-4K on top of this.
Even so, 1.8% seems high. Worth keeping an eye on this. The rest of it looks good though.
