(19,298 mi on 2005 Toyota 1GR-FE engine) 4408 miles with Mobil 1 Extended Performance oil filter, Toyota /Denso air filter, Amsoil (ASL) 5w-30, 5.25 oz LC20, 4 oz Schaffers #132. Mostly cold start 7 mile short trip driving. Lucas UCL used at 1 oz per 5 gal gas for all but last 300-500 miles. FP60 used last 300-500 miles at 1 oz per 5 gal gas. Oil changed 6 times previously. Used synthetic oil since first 1100 miles.
UOA done by Oil Analyzers.
Sample date---11/12/2006
Miles on oil---4408
Miles on engine--19,298
Oil------Amsoil (ASL) 5w-30
Oil filter -----------Mobil 1 Extended Performance
Air filter------------Toyota/Denso
Oil additives----5.25 oz LC20, 4 oz Schaffers #132
Fuel additives----Lucas UCL apprx 4,ooo miles then FP60 at 1 oz per 5 gal
Iron------------------6
Chromium----------0
Lead-----------------0
Copper--------------1
Tin-------------------0
Aluminum----------3
Nickel---------------0
Silver----------------0
Silicon--------------19
Boron---------------100
Sodium-------------0
Magnesium--------17
Calcium------------2775
Barium-------------0
Phosphorus--------670
Zinc-----------------844
Molybdenum------110
Titanium-----------0
Vanadium----------0
Potassium----------0
Fuel (% vol)------- Vis @ 40 C--------n/a
Vis @ 100 C-------10.79
Water (% vol)------0
Soot/solids----------n/a
Coolant--------------NO
TBN-----------------3.54
Oxid-----------------11.0
Nitr------------------18.0
Change--------------yes
I assume the higher silicon level is due to having driven approx 4-5 miles in extremely dusty air (like dense fog).
Analysis recommendations: No corrective action required. Oil suitable for continued use. Resample at next regular interval.
Particle count done by Blackstone Labs:
ISO code (2)------15/12
ISO code (3)------15/15/12
>= 2 micron====631
>= 5 micron====233
>= 10 micron===64
>= 15 micron===25
>= 25 micron===5
>= 50 micron===0
>= 100 micron==0
Previous UOA here:
http://theoildrop.server101.com/forums/s...ge=1#Post253449
Currently running with Amsoil (ASL) 5w-30, Amsoil EA oil filter, new Toyota/Denso air filter, and LC20 at recommended dosage.
Miles on oil---4408
Chromium----------0
Aluminum----------3
Magnesium--------17
Molybdenum------110
Vanadium----------0
>= 2 micron====631
>= 5 micron====233
>= 10 micron===64
>= 15 micron===25
>= 25 micron===5
>= 50 micron===0
>= 100 micron==0
Previous UOA here:
