AMSOIL 15W-40 AND LUCAS OIL STABILIZER
San Bruno, CA
HERE ARE RESULTS OF 4 QUARTS OF AMSOIL 15W-40 SYNTHETIC WITH I QUART OF LUCAS OIL
STABILIZER IN A FORD 302 WITH 4000 MILES ON THE OIL. TEST WERE DONE BY OIL ANALYZERS
INC.
IRON 7PPM
CHROMIUM 1PPM
LEAD 5PPM
COPPER 3PPM
TIN 1PPM
ALUMINUM 6PPM
NICKLE 6PPM
SILVER 1PPM
MANGANESE 1PPM
SILICON 5PPM
BORON 35PPM
SODIUM 3PPM
MAGNESIUM 0PPM
CALCIUM 4315
BARIUM 0PPM
PHOSPHOROUS 1287
ZINC 1396
MOLYBDENUM 16PPM
TITANIUM 0 PPM VANADIUM 0PPM
CADMIUM 0PPM
VISCOSITY @40C NA @100C 20.1(OUT OF GRADE)
SOOT NA, OXIDATION 2.2%. NITRATION 14.3%, TBN 11.7, TAN NA
HOPE YOU OIL GURUS FIND THIS USEFUL. MIKEYOILNUTT
Question: Why use an oil stabilizer with a synthetic oil?
Comment: This is a classic example of why NOT to use an oil additive that has viscosity thickeners in it.
Thanks for the test info guys. I do have one thought however. Why does my oil never look foamed or anything when it is changed? I just have a doubts about the "real world" viability of the test. It was not in a motor with the heat and bearing clearances and I have my doubts.
Thanx
Joe
quote:
Thanx
Joe
Not sure you are posting in the right thread.
Oil should not looked "foamed"
