http://www.amsoil.com/performancetests/sequence_3f.htm
The Sequence IIIF test is a stringent API SL, ILSAC GF-3 test designed to measure oil thickening and piston deposits in high temperature service, as well as provide information on valve train wear. The test is designed to emulate high-speed service under high ambient conditions.
OBJECTIVE
Subject AMSOIL 10w30 Synthetic Motor Oil (ATM) to an independent API Sequence IIIF Test to determine its effectiveness in preventing deposit formation and providing wear protection in high temperature conditions.
SPECIAL CONDITIONS
Because AMSOIL is formulated to provide superior performance over extended drain intervals, testing was allowed to continue for 240 straight hours, three times the length of the standard Sequence IIIF test.
TEST PROCEDURE
Testing is conducted with a 1996 model Buick 3800 Series II, water-cooled, four-cycle, V-6 engine. The test engine is an overhead valve design (OHV) with a single camshaft operating the intake and exhaust valves through pushrods and hydraulic valve lifters in a slider-follower arrangement, and it has one intake and one exhaust valve per cylinder. Induction is performed through a modified GM port fuel injection system with the air-to-fuel ratio set to 15:1.
Running unleaded gasoline, testing begins with a 10-minute initial oil leveling procedure before slowly working its way up to test speed, temperature and load conditions. Testing continues at 100 bhp, 3600 rpm and 155° C oil temperature for 80 hours with oil checks performed every 10 hours. Kinematic viscosity increase and wear metals (Cu, Pb and Fe) are evaluated at every 10-hour interval.
At the end of 80 hours, all six pistons are inspected for deposits and varnish, camshaft and lifters are measured for wear and oil screen plugging is evaluated.
TEST RESULTS
Even at three times the standard test length, AMSOIL 10w30 performed three times better than the test limit in the area of kinematic viscosity increase, and it excelled in all areas of the test. AMSOIL 10w30 Motor Oil kept viscosity increase, wear, deposits and varnish to a minimum. The pictures below demonstrate the superior protection provided by AMSOIL Motor Oil throughout 240 straight hours of Sequence IIIF testing.
While conventional motor oils tend to thicken and lose their lubricating effectiveness, AMSOIL Motor Oils are formulated to maintain their viscosities over extended drain intervals. The results of the Sequence IIIF test clearly demonstrate the long drain capability of AMSOIL 10w30 Motor Oil. Even after being subjected to a triple length Sequence IIIF test, AMSOIL 10w30 performed three times better than the standard test limits. The competitor's motor oil shows dramatic viscosity increase in less than half the time.
Chris Thornton
2000 VW Golf TDI
1998 VW Passat 1.8T
OBJECTIVE
SPECIAL CONDITIONS
TEST PROCEDURE
TEST RESULTS
Chris Thornton
2000 VW Golf TDI
1998 VW Passat 1.8T
